arjax
As the title states I am researching a BHW swap into a 2001 allroad. I have a couple of questions that I hope someone can help me with.
Gas Tank
Can I use the existing tank?
Can I use the existing fuel pump? In a phone conversation with DeWitt he mentioned using a pressure regulator. What pressure does it need to be? Who makes one or where to buy one?
Any additional modification needed to the gas tank?
ECU
Do I need a different ecu or can my current ecu be flashed? If I need a new one which one do I need?
Instrument Cluster
Do I need a new instrument cluster?
Gearing
I will be swapping out the Tip for a 6speed from a 2001 A6. What gearing should I be looking at for the 6th gear?
Miscellaneous
Wiring Harness - Any good threads that discuss this? Would having one built by Fast Forward be a good option? The donor car I have an eye on is an 2004. Does it have what I would need to make my own?
Thanks in advanced for any insight and help.
Gas Tank
ECU
Instrument Cluster
Gearing
Miscellaneous
