Did some calculations too:
Suppose the engine is doing 900RPM.
That's 900/2*4=1800 strokes per minute or
108,000 strokes per hour.
- factor 2 because of the 4-stroke operation:
one active stroke every 2 cycles
- factor 4 because of the 4 cylinders
Suppose I read 340mg/stroke from the ECU at idle
That's 340mg/stroke*108,000strokes/hour=36.7kg/hour
Let's check:
1.9l engine at 900RPM
1.9l*900/2=855 l/min => 51,300l/hour
Air is 1.29g/l so 51.3*1.29=66.2kg/hour(?)
Error of a factor 2 because I have to calculate 900*4=3600 strokes per minute or is the cylinder air pressure when the intake valve closes 36.7/66.2=0.55 bar?
I think the latter. Looking at the TDI data of an AFD engine (tdi-technik-eng.pdf referenced many times in this forum): 75kg/hr at 1300 RPM.
1300RPM/900RPM*66kg/hour=95kg/hour That's to much. That can't be true because at 1300RPM the turbo is doing at least something, resulting in more than 95kg/hour.
With the same pressure: 1300RPM/900RPM*36.7kg/hour=53kg/hour
With 0.78bar in stead of 0.55 due to turbo: 0.78/0.55*53=75kg/hour.
And 75/53*340=480mg/stroke at 1300RPM doesn't seem to be way of.
Who can confirm this or show the correct calculation?
