El Serch
- Joined
- Oct 27, 2010
- Location
- San Diego
- TDI
- Jetta 2003, 5 speeds, pass away, current Jetta 2011, Manual 6 Speed
Question, any one know has replaced the kessy on your car?
The Jetta I just brought, don't have the touch sensors, the previous owner changed the doors without the handle sensor.
Where I can get instructions on how to replace the handle?
here is the VCDS reading:
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0146050023
Coding: 030C0C
Shop #: WSC 00066 000 00000
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 336427509A3569DE47-8066
5 Faults Found:
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 82
Mileage: 218188 km
Date: 2021.08.22
Time: 15:27:20
65813 - Supply voltage
U1011 00 [008] - Voltage too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 218188 km
Date: 2021.08.22
Time: 15:27:20
1052935 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 218188 km
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 82
Reset counter: 58
Mileage: 218104 km
Date: 2021.08.13
Time: 23:11:38
1057291 - Antenna for Keyless Entry System; Passenger Side
B1170 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 35
Mileage: 218104 km
Date: 2021.08.13
Time: 23:14:16
Coding: 030C0C
5 Faults Found:
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 82
Mileage: 218188 km
Date: 2021.08.22
Time: 15:27:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 218188 km
Date: 2021.08.22
Time: 15:27:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 218188 km
Freeze Frame:
Fault Priority: 4
Fault Frequency: 82
Reset counter: 58
Mileage: 218104 km
Date: 2021.08.13
Time: 23:11:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 35
Mileage: 218104 km
Date: 2021.08.13
Time: 23:14:16
