key opens door but does not turn off alarm
DeanOusterhout
Virginia
2015 Golf TDI, sold the 2000 golf and jetta
Shucks.... for a while my key has not opened the door automatically, but the key would open the door and deactivate the alarm. This afternoon, the key opened the door, but when I opened the back door the alarm sounded and using the key in the door or the ignition did not deactivate the alarm.
Thoughts?
Jesus Is Lord
Hersey, MI
2005 Passat TDI Wagon 144,000 2003 Eurovan VR6 2007 Touareg V10 TDI 158,000
The key lock cylinder or module is bad, possibly both.
DeanOusterhout
Virginia
After looking up alarm issues I discovered I should have done some research before posting... It looks like there are some good posts on fixing the switches and solder joints that frequently fail on the door lock modules.
http://forums.tdiclub.com/showthread.php?t=414620&highlight=key+turn+alarm
If you have a link to a good how to for taking the door apart I am now looking for that. Ok... I found a pretty good explanation here:
http://www.myturbodiesel.com/wiki/door-card-panel-removal-on-a-mk4-jetta-or-volkswagen-golf/
Powder Hound
I vote for just fixing the solder joints, but I am biased because that has worked for me on more than just my own cars.
The labor is the same, pretty much, but you don't have to futz around with the switches.
Cheers!
PH
