Key FOB won't work at all
I'm having a problem where my key fob stopped working all together.
I've got a 2003 Jetta Wagon TDI
First, what happened was the common door lock module / door switch problem where the puddle light would never turn on and the car did not recognize when the door was open. So it acted like it was always in the closed position. I didn't worry about that right away because it never gave any problems with the alarm going off or anything. And the doors would still lock and unlock just fine with the fob.
But then after a few weeks or a month of that being 'situation normal' the fob quit working. I figured that it must just be something related to the stupid door switch problem, so over the weekend I finally took apart my door, and fixed that problem. Now the door works just fine, but the fob still does nothing.
So I tried this today...
CCM Measuring Block
Okay, It's Group 15. "Remote Control Button"
Reading is 0 0 0 0.
First 0 = Unlock Button
Second 0 = Lock Button
Third 0 = RLR (rear lid release)
Fourth 0 = Panic button
Each 0 changes to 1 when corresponding remote button is pressed.
Except, in my case, for the Unlock button (first 0). Reading remains at 0 when unlock button on remote is pressed. This is the same with both remotes.
I tried this, and the zeros never change at all. So I guess according to that result, my fob is dead. But when I went in to reset all keys and have the car re-learn the remote, that worked just fine. I cleared out the remotes by having it set to 00 and saving. Then I switched it to 01, clicked TEST, then SAVE, then pushed the door lock button on the remote and the car horn honked to confirm that it had learned the remote. Then I turned off VCDS and took the key out of the ignition to try it, and nothing. I also tried putting a new battery in the fob. And still nothing.
What else can I try? I wish I could try another fob, but I only have one. So for now I have to keep putting the key in the door to unlock everything.
It makes no sense to me though... How can the button on the fob work in order to pair the fob to the car, but when I push the buttons for the fob signal test, everything stays on zero, like I'm not pushing any of the buttons.
Does that mean my CCM is bad? But again, why am I able to pair the fob? If the CCM is bad, then the pairing shouldn't work either. Right? Unless maybe it is very strangely, and coincidentally intermittent.
Any suggestions on what's wrong, or what else I need to check would be much appreciated.
Thanks.
