SVTWEB
For those of you with the KESSY system in your car. If you get the dreaded "Key Not in Range" error, you can still start the car using the non-published bypass.
1) keep the key in the folded position.
2) Place end of key fob to start button as if you were going to use it like a normal key. (Switchblade Closed)
3) Press start button and hold.
Car will now start. Even though we have a "Keyless" start system, there is still a reader coil built into the start button that will allow the car to start if an authorized key is within range of the reader coil.
So for anyone who gets that "Oh $h!t I'm stuck because my key won't work" feeling, now you have a way to get the car started and taken to the dealership for them to re-initialize the Kessy system.
