lundgrji
- Joined
- Mar 3, 1999
- Location
- Minnesota, USA
The following tests were performed on my 98 TDI NB, 51,800 miles, stock chip, ect..., 70 deg F, humid (90-100%), 1000 ft elevation.
Using a Dwyer Magnehelic 60" water vac/pres gauge I measured the pressure inside the air box, (clean side of filter) between the air filter and turbo. I used the existing fitting on the air box to attach the gauge.
Stock VW air filter had 4,500 miles on it, and K+N was new.
4th gear full power:
RPM Stock VW filter New K+N filter
2000 8" H2O vacuum, 7.2"
3000 10.8" 10.7"
4000 15.3" 14.5"
1st gear full power @ about 4400 rpm
20.3" 20.3
2nd gear full power @ about 4400 rpm
18.0" 17.7"
3rd gear full power @ about 4400 rpm
17.0" 16.5"
Results are the average of 3 runs each. A Wett-chipped TDI should show even greater differences with the increased air flow.
Also, a dirty paper filter will probably lose more flow than a dirty K+N.
Next, I checked the pressure inside the air box on the dirty side of the filter, between the filter and intake ducting inside the fender. I was expecting to see very little vacuum inside this area, since it should be atmospheric pressure, unless the inlet ducting within the fender presents a significant restriction. Tests were done with the K+N in place and same conditions as above. I used the small drain hole in the bottom of the air box to attach the gauge.
4th gear full power
RPM
2000 6.8" H2O vacuum
3000 11"
4000 14.6"
1st, gear full power @ about 4,400 rpm
20" H2O
2nd, gear full power @ about 4,400 rpm
17"
3rd gear full power @ about 4,400 rpm
16"
The results are surprising, with the inlet ducting presenting as much restriction as the air filter. It's like having 2 air filters in series. I plan to modify the existing ducting or add a second inlet hose.
To convert inches of water into psi, multiply inches water times .03613. To convert inches water into inches mercury, multiply inches water times .07355.
Given a max of 20" water, this equals .72 psi, or 1.47" Hg. With roughly 14.5 psi atmospheric pressure near sea level, that .72 psi drop is about a 5% loss of air density. This is about the same as being 1,500 feet higher in elevation.
And remember, these tests were done on a stock engine. If I get ambitious, I might check what the MAF screen is worth.
Some interesting observations:
Max pressure drop was always seen in 1st gear.
Bliping the throttle in neutral created about 10" h20 vac inside the air box.
The first run always gave the highest pressure drop. I assume the intercooler heats up, raising inlet temps, reducing power and boost and air flow. The difference was up to 3" h20.
Driving steady at 65mph showed about 2"h20 vacuum.
3000 10.8" 10.7"
4000 15.3" 14.5"
20.3" 20.3
18.0" 17.7"
17.0" 16.5"
4th gear full power
RPM
3000 11"
4000 14.6"
20" H2O
17"
16"
