World's Fastest Diesel
JCB Diesel Max
http://www.jcbdieselmax.com/html/home.php
350.092MPH / 563.418 kph
Technical Specification
Engine -
Two JCB444 common rail injection diesel, bored and stroked to 5000 cc, dry sumped and inclined at 10 degrees. Twin compound turbochargers with twin compound intercoolers. Ice tank cooling (capacity 180 litres)
Power - 750 bhp (560 KW) at 3800 rpm
Torque - 1105 lb.ft (1500 Nm) at 2000 rpm
Fuel tank Capacity - 9 litres
Transmissions -
Forward transmission and final drive connected to forward engine;
rear transmission and final drive unit connected to rear engine.
Six-speed barrel-shift transmissions driven through torsional dampers and oil-immersed multi-plate clutches.
Steering Rack and pinion, to front wheels
Brakes Split circuit; unique design carbon rotors and twin stators.Exhaust brakes for front and rear engines, manually operated twin parachutes.
Suspension Independent all round via twin wishbones, coil springs and hydraulic dampers
Chassis Hybrid square steel tube spaceframe with bonded carbon composite panels
Body Aerodynamically designed - cdA <0.15m2; carbon composite materials
Wheels and Tires 23 x 15, Goodyear Dimensions
Length 9091mm
Width 1145mm
Height 979mm (to top of canopy, at run speed) 1337mm (to top of fin)
Front track 800mm
Rear Track 600mm
Wheel Base 5878mm
Weight 2700kg including fuel, oil, ice and water coolant and drive
