dieseljunkie
I had my glow plugs under manual control with a separate relay/solenoid but decided to go back to ECU control. I have a light bulb connected to the glow plugs so I can see whenever they are being powered.
This morning ambient temp was around 60F. I have VCDS monitoring group 012. All glow plugs are new and are good.
With ignition on:
glow plug status = 0101000 (all 1's=off)
light bulb = off
glow LED= off
After engine start:
glow plug status = 1011000
light bulb= on (glow plugs being powered)
glow LED = off
The light bulb remained on constantly for about 30 seconds as the coolant heated up and then shut off, then glow status = 11111111
My cluster temp gauge does work and VCDS does indicate correct coolant temp. I did put an ohmmeter to the dual temp sensors in the coolant flange on the head and verified that both sensors had the same resistance reading. I did not verify wiring continuity from the sensors to the cluster or ECU. I need to find a wiring diagram to do that.
Based on the above info. What's wrong with my glow plug system? Is the adaptation incorrect?
With ignition on:
light bulb = off
glow LED= off
After engine start:
glow LED = off
