MEgearhead
I have been fighting an intermittent stall on a 05 BHW for over 5 years. Nothing ever shows up on VCDS. It will not immediately restart. It has stalled under power, coasting, and idling.
It seems to be a fuel supply problem as I have to cycle the ignition switch at least 30 times and even then it takes about 4 times of cranking for 5 seconds. On 4 occasions I had to have it towed home, the last time I towed it, after using VCDS to run the lift pump 3 times and around 15 - 20 seconds of cranking it started up and ran fine.
At first I thought it was a lift pump problem, but have never been able reproduce a lift pump failure. I did notice some pitting on the fuel pump relay contacts, so I replaced it with a new relay. I've removed the lift pump from the tank twice and run it in a 5 gal bucket of fuel. It works perfectly, and the venturi siphon gizmo keeps the cup full and overflowing.
I thought it might only happen at 1/4 tank or less, but it happened today at over 1/2 a tank. The first two incidents were around a year apart, but now it's down to nearly every week.
Once I thought it might be a fuel filter, but it has happened after less than one tank on a new filter. I change the fuel filter at each oil change, cut every old filter open, and have never seen any sediment or water.
Any suggestions are greatly appreciated. Thanks!
