geostar
On my 2009 Jetta TDI, I started seeing a CEL with a P2015 code (Intake Manifold Flap Actuator, Circuit Range) about a year ago. After clearing it with VAG.com, it kept coming back. I ran it with the CEL for many months, but I needed an inspection sticker, so I needed to act on it.
I pulled the Intake Manifold Flap Actuator and bench tested it by applying voltage across the motor pins and the actuator arm moved appropriately. I was convinced that the motor and linkage was operating properly. Also, the linkage and the arm on the manifold operated smoothly, without any effort.
I plugged the actuator into its connector and laid it on the engine, without mounting it to the manifold, so that I could watch its operation with the car running. When I started the engine, it would move back and forth in some sort of hunting mode. Then it would throw a fault, stop moving, and the arm would go to its end of travel. This must be safe mode.
One in this safe mode, with the car still running, I could get normal operation, by clearing the fault and then manually moving the arm off its hard stop limit. Then it operated normally, and I could see the arm move as someone stepped on the accelerator pedal.
After doing some research and talking to a few mechanics, I learned that the actuator and intake manifold is sold as a system, and the actuator cannot be purchased alone. The part is dealer only and a mechanic quoted $1,000 for part and labor for installation. Ouch! Perhaps the system is in-separable because the actuator is calibrated for the actual mechanical flap movement. Our German friends are sometimes too precise.
Then I came across a most wonderful link:
https://sites.google.com/site/p2015fix/
This dude, had experienced the same problem and he attributed it to a linkage and flap system, that dimensionally changed in a way that caused the actuator/sensor to sense an out of range situation. Well, this brilliant man, found this out with trial and error and created a working fix by externally limiting the range of travel. My hero, and he saved me $$ and avoided an invasive procedure.
