tactdi
I installed a NewSouth 0-35psi boost gauge, and am not getting a reading at idle. At about 2000 RPMs, I can see the gauge move a little off of zero.
I double checked the pressure line from the fitting on the intercooler pipe to the guage, and do not see any kinks or pinches. For the intercooler fitting, I drilled and tapped a hole to install the fitting that came with the gauge. I installed the fitting on the hard plastic pipe that runs by the cam belt cover before the 90 degree bend into the intake.
http://home.comcast.net/~ta.cohen/pwpimages/IMG_0045.jpg
Is this the proper place for the fitting?? Anything else to check? Maybe the 90 degree fitting on the back of the gauge?
