2000 Beetle 1.9 TDI
I replacing the timing belt around 20k miles ago and set the timing to spec, 0.4* BTDC, I re-checked it on VCDS today and it is still at 0.4*
My question is what are opinions on use the adaptation setting to advance it to maybe 2.0 degrees ? I have read that advanced timing helps with cold starting and perhaps in other areas, this car has always seemed a little on the stubborn side on cold mornings.
I also adjusted the injector quantity today, hammer mod style, it was at 5.5 I set it to 3.6
Thanks for your input.
