jasonTDI
TDI GURU Vendor , w/Business number
OK, those of you with NEWER TDI's (I don't know when the change happened) Need to heed this.
If you are doing the 5th gear mod there is now a different bolt holding down BOTH cogs. It is not a T60 torx any longer. It is a 14mm XZN or triple-square bit. NOBODY stocks these! Everyone has up to 12mm. It is a special order bit.
I'd say anything built 05' or later for sure have this bit. This was an 06' Golf.
Needless to say I was as disappointed as the customer when I could not do this. It's a bit I have never had a use for.
