turbocharged798
I'm kinda at wits end here. Long story short I have a 99.5 gasser shell with the gasser body harness, an 03 ALH ECU and engine harness, IMMO3 cluster and CAN airbag controller(swapped all the pins over). Had to make an adapter harness for the plug by the headlight. On the engine side of things, things are all good, everything is communicating over CAN like it should. Air bag module works as well and is communicating with the cluster.
Now the problem is that the cluster won't talk to the CCM because before MY 2002 there is no comfort CAN-BUS running to the cluster. The immo3 cluster won't see open door or chime at all. In the can gateway I get an error for the comfort bus, no communications. So to rectify this situation I ran can wires from the CCM to the cluster, pins 8 and 9 which according to Bentley is for the comfort bus to the cluster. The later MKIV double din radio also talks over this bus. Now I get code for faulty comfort bus. So it looks like the 99.5 CCM does not talk to the immo3 cluster. Also it appears its the same situation for immo2 cars, no cluster connection to the comfort bus.
How are people making immo3 clusters work in immo2 cars then? I don't see how immo3 is backwards compatible with immo2.
My last option is to swap to a later CCM and change out the window motors to match. Really isn't that bad but if I don't have to do that then I won't.
