I'm trying to figure out the details of an Immo3 FIS cluster swap for my Immo3 2004 Jetta, and need to clarify the coding procedure before pulling the trigger.
I'm being confused by folks saying they go to the dealer to get the Secret Key Code... which hasn't been possible for a few years, if I correctly understand the GeKo system that VW now uses for Immobilizer coding. A dealer can no longer give you a SKC because they never actually see the number.
If that's the case, how do you actually do the cluster swap, since the coding from your stock cluster is required to adapt the new cluster? Must you perform the swap at the dealer, while the dealer scan tool (VAS 1551?) maintains the SKC, and then flashes it to the new cluster after the swap? I'm very skeptical that my dealer would co-operate (presuming they'd even have a clue what I'm going on about).
In lieu of the dealer...
From this discussion, the 7-digit SKC "is a reversable hash of the 4 digit login combined with the workshop code and the date".
I understand there are tools available to read the SKC (VAG-TACHO, VAGdashCOM), but does having JUST the SKC help me install (code) the new cluster? What about needing the date the SKC was generated? Or, do these tools actually read the 4-digit PIN/Login Code, and I would use that instead of the SKC?
Maybe I'm not asking the right questions... but hopefully someone with an Immo3 who has done the swap knows what I'm trying to figure out.
Thanks...
Thanks...
