I have a customer that came in about 6 weeks ago with a bad ignition switch. The car had no head lights, horn, wipers, and turn signals. So I get the wiring diagram out and found that the red wire with black stipe at the ignition switch has no power coming out of it. No problem replace the ignition switch and everything worked great. I should also add the car had 2 bad fans and a blower swithc on the dash. So after 2 fans one ingniton switch and ac control it went out the door.
Today it comes back with the no lights,horn and wipers again. The switch is bad again,but this time the red wire on the switch harness has clearly gotten hot and partially melted the coating where it attaches to the plug. The wire still has good power on it. I plug a new switch in and everything works again. I can not find any reason for the burnt wire other than a shorted switch. All grounds are good and relays seem to be working properly.
I am 99% sure that the switch shorted out some how and cause the damage to the wire. Just wondering if anybody has seen this before.
The wiring diagram shows that that red wire is fed power from the load reduction relay(100) It apears to be working great. I hate to send this car out the door only to have it happen again and do wiring harness damage.
Thanks for any help.
