JPuck
- Joined
- Oct 7, 2002
- Location
- San Francisco Bay Area
If a VW tech can reflash the ECU, why can\'t a chip tuner do the same?
Maybe I'm misunderstanding the issue, but I'm pretty sure I've heard of people having their ECU's reflashed by VW techs. Maybe that's just from my 1.8t days, but I seem to recall them doing that occassionally. So my question is, if they can do that (presumedly without having to remove a chip from the board), why can't a chip tuner like Upsolute do the same? Why does the tuner have to remove a chip in order to reflash it? It would seem that in theory, if VW can reprogram the ECU by hooking up a harness to it, then a chip tuner should be able to do the same.
Am I misunderstanding things? Is it a technical limitation? Is it a factor of not knowing the code well enough to do it the same way VW can?
