robnitro
Hi,
My commute changed and I have a lot of stop and go and crawling.
So, I changed my ecu to run a lower idle speed- previously 840, now 756 rpm. It's actually quite smooth because I use the stock dogbone, albeit with the swiss cheese rubber replaced with the softest poly one I could find.
Group 13 looks fine too... no real difference from other idle speeds.
Are there any technical issues to running 84% (756/903=0.84) of normal idle speed?
