With tune do you drive in D or S now? How much $? Did you only do DSG tune or did you get engine tune also? If I get DSG tune, can I no longer take it to VW for service?
Normal everyday on my commute back and forth to work (40 miles) I drive in D. I'm looking for higher MPG's there.
If I go to the city then I will put it in S mode because it gives some better response and makes me happier.
I will use manual mode for down shifts and what not instead of the brakes.
When I did mine I did a DPF/EGR delete and had a Malone Stage 2 and DSG tune done. I was in a position where I needed to do something with my DPF and in the long haul removing it all together will be cheaper for me. I did everything for about $1450; tunes($1050) parts ($700) minus what I got for scrap so far. I still have some used parts that I could sell and some scrap that might be worth a few dollars sitting in the garage.
parts I put on.
Buzzken Down pipe and mid pipe connected to factory muffler. No resonator or cat in my system. It smells a little but I do not mind.
Race pipe from fixmyvw.com installs perfectly and has a tap for the next part.
Newsouth performance mechanical boost gauge. I have it installed in a custom pod in the bottom left corner of the wind screen where it meets the A pillar/dash.
ESP/Traction control off button
I got all my parts from fixmyvw.com I waited for good deals and what not. They had a month were shipping was free if you ordered any of their exhaust stuff and I got most of it then.
If you want I can give you links to exactly what I ordered.
