scurvy
Good Ol' Boy
Interesting. My wheels had no wobble at all but made an awful grinding racket when running on jackstands. Must be different failure modes - you can see how bad the races were pitted on mine from the postmortem pix.Another case where turn direction proved wrong. That method on mine definitely points to driver side. The jackstand method didn't help - neither side was noisy. But the other test of grabbing the wheel at the top and bottom made it perfectly obvious that the passenger side is bad.
FWIW, somebody asked me what OEM bearing I used to replace the bad one so they could look up whatever replacements they wanted. The original replacement was a FAG 801136; it was replaced with an SKF GRW237 after I forgot the circlip.
