Guess I should have mentioned pulling out of mall parking lot in evening and not noticing my full light package was off cause I had direct ahead illumination. ANyway, looking forward to some info on how to make my lights "normal."
paramedick said:Look on the firewall in front of the driver. See the little plug with yellow wire on each end? Disconnect and you're done.
Before you A3 guys ask, look in the area of the fusebox under the dash. You will see the same plug/yellow wires.
That IS for the Passat.tbatdi said:What about on a 1997 Passat TDI?
Logismoi said:will the TFL "cover-up" work with the MARK 5 (06-07) models ?
Thanks!
Thanks!
Jackilus said:Why not just pull the wire out from the back of the plug?
Fully reversible.
Actually DRLs are not a requirement in most places, including most places with strict safety laws. But there's no real reason to decide...Chemboy said:TAKE THIS DRIVER'S LICENSE AWAY!!!!!! Safety is not an option, it's a requirement!
So I guess I'll have to spring $350 to get rid of the DRLs, that annoying 'honk' when I lock the doors and the 'anti car-jack locks'.subspd said:10then34 go back a couple posts it explains on our cars you have to change the computer there is no simple way to turn them off... urgh.
Anyone have VAG-COM in ATL that would turn mine off?
