Adal2154
2005.5 jetta I'm having a p0299 code car goes in to low power mode randomly.
If I turn off the car and back on its fine.
I have replaced the n75 after sending Malone a log he said the Gaines are not closing but its trying sill does it
I tested the waster gate actuator with my mighty vac holds at 20 for quite some time I left it for a few hrs and it dropped to15
I have checked all inter cooler lines they are tight
I put a t in the line from n75 to waste gate and I put a vacuum gauge on it it pulls 20ish on start up but then settles at 8-10 car seems to boost to 12psi
When the car goes into low power mode the vacuum goes to zero and the boost stays at zero
Any suggestions I do have a vcs if there's some readings I should take
