Spike Strip
Sorry for the newb question, but I searched. I'm stuck.
Other threads said in order to remove the FCM, you have to remove the battery box to access a couple of bolts... OK, easy enough...
Well, I removed mine and that's where a bunch of the harness is and I can't get the harness out of the way (the plastic hold-down they're snapped into, actually) ... Bolts are appox where the red square is ?? (in pic below)
Am I doing this right. Bentley says nothing on this.
btw, is there a trick to removing the FCM connector closest to the transmission ? I've pushed, pulled, stuck a screwdriver in the slot... nothin'
'05 Golf BEW Auto.
'05 Golf BEW Auto.
