jgunn
I checked the forums first and found plenty of related threads, but none that still had active pictures, so here goes:
I believe both the primary and secondary latches on my hood are not working. I pulled the hood release and it didn't pop, but I was able to get the hood to "pop up" by giving it a firm tug, so I think the primary latch just needs some lubrication. However, at the same time, the secondary latch lever didn't pop out and when I reach in to pull it out, it moves freely as if it's not connected to anything. Looking inside, I can see that the primary latch has released and the hood has popped up, but there is still another latch holding the big hood ring solid so I can't open it.
I just want to get it open so I can refill my washer fluid and lubricate the latches to see if that fixes the problem but I can't tell how to manually release the secondary latch when I'm looking through the 1" slot between the hood and the grill.
Can someone post a picture of the mechanism, and/or describe how to do a manual release so I can open the hood?
Thanks in advance,
Jef
Thanks in advance,
Jef
