emerscape
Going to install a set of HIDs into a set of Ed's lights. The setup I have came with a relay instead of canbus connectors. I've done a bit of reading, it sounds like Canbus would be easier to set up but a relay is better given the voltage requirements of the HIDs on startup. The question I have is... is a relay a better approach? Also when installing the relay is it ok to connect right to the positive side of the battery and ground to the frame or should I go to an empty post on the fusebox?
