dieseldorf said:
I posed my question to Daniel. Here's how he replied:
This is a typical HID cluster salesman's pitch. To make things worse, it is right with quite a few inferior aftermarket kits. But it is not right for all kit/headlight combinations.
Yes HID lights are sooo different, of course.... except if you look into ETOS/ETKA or compare on real car, optically the headlight clusters for Superb differ in ... wait for it... nothing between HID and non-HID version.
Sure, there is a ballast for HID, and the bulb holder is different to accept the D1S and place the arc at the correct position, plus finally the levelling motors use different signalling to allow front/rear automatic headlight levelling. But optically, headlights are the same. And so they should be, as a well designed projector headlight really should not care what is used to generate light at the focal point.
Years ago I did a PhD in high power lasers
, so I might just know what I am talking about
I really liked the section which first said that projectors really do not care about the light source, but then pointed out that cutoff is not everything. It is not, but it is THE problem of retrofits, especially the reflector type arrangements. Usually, if you look at problems other than the cutoff, the main issue is the slight shadow caused by the HID bulb support. Does not bother. In general, the projector light arrangement replicates the light/shadow pattern inside the reflector at infinite distance from the headlight (ie in the far field, but generally even a few tens of headlight focal depth are enough). Unless you have a seriously strange light source behind the cutoff edge inside the headlight, you'll be OK. Typical problem case are H3 retrofits, as these quite often stick too far into the reflector and the light source is too close or even past the focal pattern.
Most of the problems that happen, happen with the reflector type arrangements, I'd say never ever retrofit HIDs to reflector type clusters
Unfortunately, many do.
I also want to point out that a lot of problems people are having with retrofits are electrical.
daniel said:
HID headlamps also require careful weatherproofing and electrical shielding because of the high voltages involved. These unsafe "retrofits" make it physically possible to insert an HID bulb where a halogen bulb belongs, but this practice is illegal and dangerous, regardless of claims by these marketers that their systems are "beam pattern corrected" or the fraudulent use of established brand names to try to trick you into thinking the product is legitimate. In order to work correctly and safely, HID headlamps must be designed from the start as HID headlamps.
Yes, get scared, run away and pay 5 times more for headlight clusters, which may be identical to the one you are using now, except for a Philips ballast and a different bulb holder. You will still have to spend a lot of effort on upgrading the wiring, and on complete replacement of your perfectly good levelling system with another, less than ideal one.
As for legality, of course anything that costs 3x cheaper aftermarket than from factory, must be illegal, otherwise the motoring industry clique would not be able to rip you off at each new car purchase
High beam DRLs are legal in US, but illegal in Europe. Does that mean that they do not work in Europe
I did not think so.
Having said all that, I do not advocate retrofits over factory fit. I had both. It is just that for my specific needs, the automatic headlamp adjustment never worked when the car had full boot of stuff, the headlights would then point 20 deg into the ground. The combination of manual in-cabin levelling as for halogens, plus HID inserts works better for me. Please also note that on my car there is little difference betwen the 2 types, and that the wiring is good for 15A+ per light, not a typical 8A+ per light. This changes the perspective.
I got the kit from XenonDepot. Good one, uses Philips components for the lot. But I would love to know a kit manufacturer that uses D1S bulbs, so that there is one box less to fit around the car.
Finally, I guess that Daniel sells entire headlight clusters
