Hi Guys,
I'm after some advice/help with mapping my car.
Build thread here. http://forums.tdiclub.com/showthread.php?t=402201
I have a sort of hybrid turbo (2052), I went to a 56mm compressor wheel and since then struggled with the mapping. The car made similar power than before the wheel change after the tuner mapped it, I did have a leak between the turbo and EM, once I fixed it I was getting boost pulsing at higher rpm (above 3K).
He pulled the boost back to stop this but killed the cars power. I though I was maybe maxing the 3 bar map sensor, changed to 4bar now.
The tuner actually gave me a lead so I can map the car myself, I have been playing with it yesterday using EDC15suite.
I struggling to find a relation between N75 duty cycle and target boost, the car is making more boost than requested.
If I load the car up from 2000rpm in 4th and do a full run it pulls very smooth, good power etc, if I lift off or change gear I end up with this pulsing of boost above 3k.
Any ideas?
Ivan
Any ideas?
Ivan
