MORE_MPG
From Vag-COM...
VAG-COM Version: Release 404.0-S
Control Module Part Number: 028 906 021 BK
Component and/or Version: 1,9l R4 EDC SG D5O
Software Coding: 00000
Work Shop Code: WSC 00000
5 Faults Found:
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
00765 - Modulating Piston Movement Sensor (G149)
35-00 - -
00310 - CAT Temperature Sensor 1 (G20)
30-00 - Open or Short to B+
00777 - Accelerator Position Sensor (G79)
27-00 - Implausible Signal
00312 - CAT Control Temp Sensor 2 (G132)
OK, started exactly like normal this morning, backed out of the driveway, accelerated to around 2,500 (by sound and feel) rpm in first then engine turned off as if a switched was flipped.
Tried to restart, turns over well, but no firing. No bad sounds. I am convinced that the problem is electrical.
Recent history...
Changed timing belt, water pump, accessory belts, oil, oil filter and air filter (7/17).
Drove about 1,900 mile round trip to Oshkosh, WI for EAA Fly-In (saw a bunch of TDI's will post about a TDIClub-EAA connection sometime.) last week.
Drove to work Monday, Tuesday and Wednesday as normal.
Any help would be appreciated!
My father is out of town for a couple of weeks, so I could borrow some parts (MAF maybe) from a '97 Passat TDI Sedan for testing purposes.
5 Faults Found:
35-00 - -
Recent history...
