srt-kapp
HELP! P0341 Cam sensor Implausible Signal
Update I need help with PO341 Camshaft Position Sensor (G40): Implausible Signal. I have replaced the cam sensor with 2 different ones now( both brand new), traced down all the wires nothing (broken or damaged), checked and cleaned all the grounds ,tested the wires at the sensor , even replaced the ECU. The timing is on at the cam also. I'm completely out of ideas and I'm trying to see if anyone else has experienced this before. Thank you
Hello, i have a 2005.5 MKV Jetta TDI
i need to retrieve the SKC or ( PIN ) i have vag tacho 5 but cannot get that to work for me.
What program or tool do you guys use to retrieve the SKC
