Erich Zimmerman
Hi All,
We just moved to the Oswego, NY area and we're trying to find someone knowledgeable about MK4 Jetta TDIs. My son had the injector pump replaced in Hartford on his Jetta before he came home from college, and now it runs like crap. It idles really rough, the CEL is on and the glow plug light is flashing. These were NOT on before he had the pump replaced. I ran the codes and only a "upper quality limit reached" code comes up.
I called the mechanic in Hartford and asked the guy if he replaced the timing belt and the water pump while he had them off and he said, "uh no, the belt looked good so I just put it back." It probably has ~150,000 miles on it since I replaced it last time.
The mechanic we took the car to thinks the injector pump timing is off; but didn't have Vag-com so he had to order the cable for his laptop. Anyone near Oswego that we can go to to have this fixed?
Thanks,
Erich
Thanks,
Erich
