JeffNLisa
Hello Forum-
I am new to this forum, but it was recommended to me by the person who sold me my car. I have spent the afternoon reading thru it, and looking for answeres to my questions. Have found lots of good info, but not several specific things. If anyone reading knows of threads where these issues have already been answered, please post links to those threads, and if everything I need already does exist elsewhere, I'll delete this thread (if I can do that).
Thanks!!
I have a 98 Jetta TDI.
1. It sags in the rear already, and I am about to add 300 lbs or so (an aux SVO fuel tank full of fuel, about 9 gallons in containers in the trunk, and a tow hitch) which will make it sag even more.
I had planned to simply put air shocks, as I have on my Mustangs, and that way just adjust the ride-height back to level from whatever weight I happen to be carrying.
But Jetta doesn't work like Mustang in that area, and the springs are built-in to the shocks -- STRUTS
Does anyone know of a way to have adjustable ride height on a 98 Jetta? Or if not adjustable, at least lifted back to stock height after adding weight hanging off the tail end?
HELP!!!!
2. I need a Class II hitch. All I can find readily available from Reese, HiddenHitch, et al, is Class I.
I have seen several Class II hitches available, one available to order at an RV place, and the other here: http://www.curtmfg.com/app guide/VW.htm
The problem is that I need to be able to go someplace that stocks it, so I can take it and hold it up under my vehicle for fit, because I need it to fit around the custom auxilliary fuel tank.
I also want it as much out-of-sight as possible when the ball-mount is not installed.
And I really can't spend a ton of cash on it!!
If anyone has any recommendations what/where I might go, or any other helpful info, please provide!!
Everything I can see on this forum about tow hitches seems to talk about Class I and for A4 or A5 Jettas.
ANY help anyone can provide me will be GREATLY appreciated--
Jeff
Thanks!!
HELP!!!!
Jeff
