Scenario: '79 Celica sat for many years, but very rarely driven. 118K original miles. Runs rough, but looks like it has had good maintenance over the years.
Plugs 1-3 had very heavy carbon build-up, with one actually bridged across with carbon. At least 2mm of hard black carbon on the outer electrode, to the point where it has cracked and broken off in places. #4 plug had light oil fouling, which I'm hoping is just a stuck oil ring. Cleaned up the plugs as best I could, and it runs much better. Dumped in fresh gas with fuel injector cleaner additive, and have been running it some to clean out the fuel system. (Hydraulic clutch is kaput, so no driving yet.)
So, I imagine the valves and piston crowns are coated with the same nasty build-up. My theory is that the PO would keep the battery up and run it now and then, but it never was driven hard enough to blow the carbon out. It does seem to be running rich, too.
I've heard of this "Sea Foam" stuff-- is it any good? Short of pulling the head and manually removing the crud, what are the options? I think I'll go ahead and rebuild the carb, since the car has spent so many years with old gas in the float bowl. I've never done that, but I'm not afraid to tackle it. Only book I have is Haynes, which is just about useless. I'm on a quest to find a real shop manual.
(I'm just posting here because I know a lot of you are long-time mechanics, and this is probably Gasser 101 to you.)
Thanks,
Lee
I'm not that familiar with old, carbureted gassers, so this is new territory for me. The car ran rough when I picked it up, so I've been assessing its condition to determine if it will be a runner.
Thanks,
Lee
