geostar
It appears that my second Mk4 needs a heater core replacement. I thought this was rare! Having experienced the replacement, I have been giving advice, “Just Do It”, but I don’t feel like doing it right now.
My second is not my favorite, because it drinks gas. Bad boy!!!
So, I am scheming an alternative repair. Sealant. That’s right I said SEALANT, but this is a gasser we are talking about.
My scheme is to just treat coil with the sealant. I would build a system that would circulate the goo mixture just to the coil. The system would attach to the two fitting on the firewall and would consist of a pump, reservoir, pressure fitting for air connection (a way to pressurize the system), float flow meter. Maybe even a heater, if heat is required to activate the goo. It will also have a pressure gauge and a set of ball valves so that I could leak check. I have all this stuff in my shop, so I don’t have to buy anything, other than maybe some fittings.
My question is what do I use for the goo? Based on my first, the top of the coil is a plastic manifold that it integrated into the firewall fittings. The coil is about a dozen 6 mm aluminum tubes shaped like a U which attach to the manifold with Orings. My failure was at the oring joint. There was no aluminum corrosion. So what kind of goo would seal the oring interface between plastic and aluminum?
