Hi! I have a 2008 Touran and my headlight washers are not working, i know i gotta have my headlights on and pull the stalk around 5 times but they don't work. I've checked under the hood, and headlight system is installed, also i've tested all the fuses both in the engine compartment and under the steering wheel and they're all fine. Windshield and rear washer are working, i currentlly can't pull the bumper from the car to test out if pump is working, is there any way to test them? In vcds it says hedalight washers are installed. I will attach some pictures.
Edit:i've tested relay 53 and it clicks every on every 4-5th pull of wiper stalk
