mech644
I drive an '00 golf, 5spd, 100k. Bought it with 50k, at 60k cleaned intake from airbox to head. Took everything apart and pressure washed carbon/oil build-up fromall parts, flushed IC until water ran clean. The cylinder head had a fair amount of carbon built up around valves. Removed as much as I dared with a stiff plastic pic with a shop vac sucking on ports all the while. Car is starting to get lazy again, loosing a RPM, so air path needs to be cleaned again.
This time EGR will not be re-installed and installing a Racor CCV filter system.
Anyone have any advice as to how to decarbon intake side of head with removing it?
I've used Seafoam on my gasoline cars with great success, introduce a pint via a vacumn port at idle, let car sit for 15 minutes, re-start and drive gently for a couple of mile, by then all carbon has been burned and blown out exhaust. Works great.
Not sure if I can do this safely on a TDI.
