T5TDI
<font size="2" face="Verdana, Helvetica, sans-serif">I don't think it works that way round. The ECU reads the ETC and actuates the glow plug relay depending on the coolant temp recorded. It sounds like either there could be a problem with the wire between the ECT and the ECU or with the ECU itself. You could check the ECT/ECU wire & mulitiplug for continuity (with the ECU disconnected) If you find that ok and want to get really serious you will need access to a break out box so you can check the ECU output to the glow plug relay.Originally posted by B3Syncro:
I am assuming that the glow plug relay is defective, and is not reading the ECT sensor correctly, but would like to hear some other opinions first.
Check any ECU grounds too, I think the ECU grounds the glow plug relay to actuate it.
