AK islandr
Not trouble starting due to cold temperatures. Before any motor issue arose my 2003 TDI wagon has been flawless. A couple years ago Fixum Haus replaced my timing belt and installed Malone chipping. Currently my trusty Jetta has over 105K and I read if I clean the MAF it could help mpg and overall health of the engine. MAF removal and replacement was very easy, I dribbled some isopropyl alcohol over the sensor and reinstalled the MAF. Since then if the Jetta sits overnight it has trouble starting. Only by using the starter to keep the engine turning does it eventually start. Now I notice there is a small drip coming from somewhere around the injector pump, that might be a coincidence.
As a test I pulled the sensor connection to the MAF before a cold starting but that made no difference. I bought a new and updated OEM MAF. After install there was no change to cold starting. Something to note is once the engine is running it performs perfectly like it always has, starts fine at anytime, acceleration is good, no missing, nothing out of the ordinary. Only when it sits for hours until it is completely cooled does it act up. Am I wrong thinking the timing of the MAF cleaning is a cause of poor cold starting and the injector drip is a separate issue? Someone suggested it might be a problem with the ECU. Is there a problem with glow plugs? Will a vag-com help find the problem?
