06 jetta tdi. 42k miles.
I don't drive it much any more.
so it I use a trickle charger to keep the battery up.
it might run once a week. I get it to operating temp, but still don't drive it far.
a few times, not every time, after sitting like this, it won't start right away like normal.
I will have to crank for a long time, several times with the gas pedal on the floor, till it finally starts to build up some revs and catches.
I have tried "priming" a few times, this last time.
key to on, without cranking, off, then to on again 3 or 4 times, hoping, if it was a fuel pressure issue, it would then start, but that didn't seem to matter.
cranking for 30 to 40 seconds at a time, till the low oil light comes on, 3 or 4 times, then it finally catches.
I read something about bad lift pumps, but I thought that might be a more consistent problem.
what else should I be testing?
if I take it out every day during the school year, I don't see this happen.
I do recall once it happened, after a short move, from the garage to the driveway, the next day I had to do the same thing, but that hasn't happened in a while.
this has probably only happened 6 times in the last year.
