TaylorMadeGolfClub
I noticed the symptoms below after the engine was overspeed (by my father) for a couple seconds. The outside temperature also dropped around the same time. Maybe one or both of these events caused the hard starting?
Symptoms:
It seems like the problem is air intrusion, but from what I've checked so far I can't figure out exactly where the air would be getting in. Any ideas for possible causes of these symptoms are greatly appreciated.
Symptoms:
- Cranks and sputters for 5-10 seconds before reluctantly starting.
- Large puff of white smoke (much larger than I've seen on this car before the issues).
- Unsteady idle until I give it a little throttle (bounces between 850 rpm and 1000 rpm).
- Low power when driving for about a city block then seems normal after that.
- The car always starts.
- The area directly underneath my injection pump was covered in what felt like caked on sand and dirt held together by a thick gummy black goo. I can't tell if it was baked on power steering fluid or baked on diesel fuel. In my experience diesel is usually sticky and wet, not gummy and dry like this stuff was. This goo was present when I bought the car before the overspeeding and temperature drop when I had no issues with starting.
- A little while ago I replaced my glow plugs and ran a can of diesel purge through my fuel system. I used diesel purge because my glow plugs showed evidence of a bad injector. This is the post.
- No bubbles in the fuel supply line to the injection pump.
- The injectors are clean on the outside.
- the entire injection pump is clean.
- Car no longer exhibits these symptoms after the first start of the day.
- The TDI timing under basic settings is dead on according to vcds.
- I have tried priming my injection pump before cold starting and noticed a slight reduction in cranking duration, but no change in the sputtering and unsteady idle.
- Inspected the seals on the thermo t, they didn't look damaged. When I pulled the thermo t out I heard fuel getting sucked back into the tank.
- Checked voltage at the fuel cutoff solenoid it was getting about 13.46V.
- I cleaned up the goo under my injection pump and haven't seen any new leakage.
