Chris_TDI_98
I was driving my Jetta mk3 TDI on highway 84, going about 60 miles per hour in the middle lane, when it stalled out suddenly.
I was able to pull over to the breakdown lane.
NOTE: There's plenty of diesel in the tank, 2-3 gallons, good quality fuel.
NOTE: A few days before, I had work done on it at a garage - they added 1 quart of 15W40 motor oil, replace both sides rear bearings, one side rear stub axle spindle, and both sides brake shoes. They remarked, on the printed invoice, that all the belts seemed on the loose side and the tensioner pulley was near its end of life and ready for replacement!
NOTE: While having the freeze plug installed back in March, the guy apparently reconnected the vacuum hoses wrong, and since then, I've had no "turbo boost effect" while stomping on the accelerator pedal, so you can't really floor it and overtake anyone on the highway. I checked with the OBD2 code reader to see if the computer was throwing up any codes, and there were some EGR related codes in there.
Back to our story.
While parked in the breakdown lane, hazards on, I tried restarting it.
It cranks only about 0.1 second, then it stops cranking, as if it's seized, and something's physically blocking it from cranking.
I looked at the timing belt (while waiting 2 hours for AAA to come flatbed it back to a friend's house).
The timing belt looks very stretched out. You can see through it, you can see the bottom grooves through the top of the rubber.
It's as if the crankshaft is trying to crank, while the cam shaft (or water pump, or tensioner pulley, or power steering pulley) is seized.
I have an OBD II code reader.
I don't have a VCDS / VAG-COM.
Calling all gurus, on this forum.
And/or TDIclubbers with insight and near Hartford, CT who might be able to come meet up and we can diagnose my car together.
Will provide ice cold beers, snacks, pizza, etc.
How can we diagnose this??
Please help.
Back to our story.
Please help.
