Head swap went well, but new problems always arise. Here is the video of it: https://youtube.com/shorts/o4oMFegPLjc?feature=share
I just hope all of these problems i am having help someone in the future.
Seems like something to do with wheels/suspension, simply by the fact that the noise alters with speed not rpm, so i would say i can rule out transmission/drivetrain.
I have had a good look underneath, and can't see anything wrong, thought maybe it was my belly pan/liners making the sound, because the screw points on them are mostly broken, but it wasn't drove the car without them for a short trip and didn't change the sound whatsoever
I do have a bad tie rod end on the passenger side of the car, but i am kinda thinking the sound isn't that. I have changed out the right side bearing (the side i think the sound is coming from) Might have done that job badly and it failed prematurly but there is no play in any of the 4 wheel bearings, 3-9 12-6 locations also when the original bearing failed (Before i did the head swap) It didn't make this noise. I have also driven in a circle at 10kmh and 20kmh to rule out cv joint, and the sound can't even be heard then, only when driving straight.
Sound is also very intermitten, sometimes it is there sometimes not, but mostly its there, either if I turn left or right. But again mostly if i turn left it goes a tad bit away. Any suggestions are nice
