DieselPower208
I cant upload more the 5 pieces of media so here's a link to the google drive
Hello guys,
I'm having a little bit of an issue with my 2003 ALH Jetta w/ 5 speed. At idle as seen in the video (my tune has a high idle addon and I just started the car) I'm getting what seems to be an injector haze similar to what I had in my 12v cummins. it also puts out a greyish smoke while accelerating. Haze is there when the engine is warm and cold. I'm not burning oil or coolant. If I am it's not at a noticeable level whatsoever. I do have bigger injector nozzles (.230) from Xman Turbos LTD. My car does have a tune as well. They are pop tested and all that fun jazz. Before I had my 2003 I had them in a 2000 ALH for about 10-12k miles. I did not notice any hazing while they were in that car. I've played with the IQ and had my local VW shop play with it as well. While adjusting the IQ they performed the hammer mod, and no resolution was found. There was a haze no matter what. My pump timing is slightly advanced, but I don't think it would be causing this. I was planning on pulling the injectors and having them re-pop tested and ultrasonic cleaned, but with only 15k miles the nozzles shouldn't be terrible. My IQ is sitting at about 4.6-4.8, car goes in on Thursday to have it brought back down to around 3.5. My MAF numbers are normal, a little above spec but I believe that is due to my tune. I have a check engine light on but it is for the glow plug harness. could it possibly an injector stuck open, but wouldn't I have a noticeable knocking sound? Im stuck on what else I should check. Im waiting on an oil sample from blackstone to check my fuel oil dilution numbers, to check for possible fuel wash.
Does anyone else know what I can check? or what my problem could possibly be? I know it's possible to get smoke when the injector pumps failing, but I killed 2 pumps in my 00 and that was a very noticeable thick white smoke. I'm trying to start will small fixes and see if I can solve this haze before picking up a new set of injectors.
Thanks guys, stay beautiful.
Car - Google Drive
drive.google.com
Hello guys,
