hudsonjrwt
- Joined
- Mar 16, 2000
- Location
- Charleston, SC
While rotating tires on my Y2K Jetta TDI tonight I notice sitting atop each front strut houseing on the strut rod a green hard plastic "doughnut" about 1 inch thick similar to a "strut bumper". It has a slot formed in it allowing it be easily removed. As it is slightly larger in diameter than the strut cartridge housing, the bottom of the plastic dirt bellows will not fit over it potentially leaving the strut rod exposed to the elements. If it was of a softer material I could accept it as being a bumper; however I feel it may be some type of shipping/packing device for the strut assembly which was not removed prior to installation. Anyone else noticed one or been down this road? Is anyone else's strut boot bottom end fastened or installed over the top end of the strut cartridge (verses dangling loose above a green doughnut)?
