The glow plug light blinking could be brake electrical problems, either the switch, a fuse or a bulb. That spot on the cluster is used for electrical problems in the gassers, I don't think it throws a code unless it stays on so it is probably a brake light system warning. You should update your location, if you are in Canada the VW recall campaign for the brake switch was WX, the TC Recall # is 2004075. There was also a recall for the Hazard Switch which was VX, TC# 2004436. There was another recall on some of the ABS Control Units as well but don't know if this would affect your Glow Plug warning lights, it was WJ, TC # 2002028. These are the only recalls I could find relating to brake or warning lights for the 2002 model year. I am not sure if the NHTSA has similar recalls/TSBs in the US.
