weedeater
Re: Glowing doesn\'t work, desperate!
The coolant temp sensor is color-coded. You have to get a replacement of the same color, even though the part numbers are the same.
There is still a 'short' here. The system is acting correctly when you unplug the sensor. Therefore there must be a short in the new sensor, wrong sensor, or a short in the plug when inserted into the sensor itself.
