JohnTF
The glow plug system symptom is that long crank - appears to be from glow plugs not coming on normal length of time for cold starts .
I've many diesels and lots of testing & repairs .
The weather here is between 30 - 50* F .
The long crank is only after sitting typically overnight / or long periods maybe half day + .
Then the glow plug light comes on for only a few seconds , even at around 30*F .
I tried disconnecting the coolant temp sensor and the glow plug comes on for , what I would call normal length of time for cooler temps and starts much easier / normal .
Put in a new sensor / no change , tested the 2 circuits [ 4 pins , figuring 2 circuits ] and the Ohms were 20K & about 19K , so should have measured 1st - and not bought a new sensor
So now my conclusion is that the engine control system does not seem ? to operate correctly with the glow plugs / temp sensor ?
Any ideas ?
So for easy starting , disconnecting sensor - then lights the check-engine-light ;(
Checked the injection timing and it varies between 42 - 43 , later I might move it to a couple degrees above / into the advanced maybe something like 46 - 47 ?
Any ideas ?
