The Horak
Hey guys. I've got a BEW that's will stall out sometimes and then not want to start. I'm hoping to get some advice. First off, here is what I get from VCDS:
Engine Module Codes:
So here is what I think: my Crank Sensor is intermittent, and when it goes, the car stalls and won't start. But here's the thing. When it won't start, I get the flashing glow plug light. Once the car starts, that goes away until the next time it won't start. I also get a check engine light, but that will eventually clear itself... So what is my next step? Do I just focus on the Crank Sensor? Would that cause a flashing glow plug light? (Sorry this is a long post) Thanks guys.
OBD II Code:2 Faults Found:
19463 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal
Freeze Frame:
RPM: 168 /min
Torque: 142.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.73 V
Bin. Bits: 00001111
Idle Stabilization: 0.0°KW
(no units): 32.0
16706 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - Intermittent - MIL ON
Freeze Frame:
Readiness: 1 1 0 0 0
So it looks like my Camshaft Position Sensor (CPS) is bad and my Crank Sensor. My guess is that the CPS had been dead for years. My car has always taken at least 5 cranks to start. But it ALWAYS started. The Crank Sensor is a new issue, I think.Mode 03: Emission related fault codes
Address 10 (Engine): 1 Fault Found:
P0727 - RPM Signal from ECU: No Signal
