tactdi
I have had my 2005.5 Jetta for over 2 years. Bought it with 142K, knowing that the manual trans was bad, and replaced the transmission, cam (it was bad), and the timing belt.
During this time, the car runs great, and still runs great. It had shown symptoms of the sticky vane (actuator) and a hiccup at highway speeds.
With the sticky vane the RPMs would stop at about 1800, and the engine would clack. The way to get through the sticky vanes was to lift and then accelerate, which would also cause a cloud of black smoke out the tail pipe.
At first this would occur infrequently, but then it started to occur almost everyday. Reading about the sticky vane, I was sure that I would be either adjusting the set screw or using the tie wrap fix.
BUT, several months ago, I found a fuel station selling 47 cetane diesel, and started to use that for every fill up. I noticed an immediate difference in how the car drove from the first fill up, and since then, I have not had the sticky vane symptom, or the hiccup at highway speeds.
Any insight on the higher cetane fuel preventing the sticky vanes?
