flan
1 of the Fuel lines in between fuel cooler and fuel filter seem to have a leak. It's in the channel attached to the unibody. This a common problem or no? There's a blue plastic hose and a black one.
Disconnect at the fuel cooler, plug and try to pull a vacuum in the engine bay. Should let you know if there is a leak.I checked that out, when I looked to see where they came out in the engine bay. It was dry in that spot, thanks for the suggestion though!
Good luck, can you post the results? I'm really curious to know what you find.that will be the plan to figure out which one is toasted
